maxum247
- Sep 18, 2007
- 1,363
Re: Flats boat PROJECT....Updated w/pics!
The plywood strips should work fine but if you can make them a little wider so the glue get's as good a bite as possible. You'll want a couple of braces, say 1 in. x 2 1/2 in. on edge under the front and back decks running crossways of the boat even though your thinking of useing 3/4 in. plywood. Glass the decks just like you would the floor deck of the boat.
You can use epoxy thickened with a fairing filler to get the look you want at the rubrail area, then if it's necessary you can lay a layer of finishing cloth down.
