sasto
- Jun 1, 2010
- 3,918
Re: Flare storage,
I like your idea of the sock, or if I can find a Crown Royal bag...doesn't need to be 'proof just 'resistant. I didn't think about the plug needing to be tight to be 'proof. Thanks, Done deal.
Put your stuff inside a tube sock. Then slide it all into the pipe.
If the pipe is mounted to a wall or something, you can easily remove everything from it instantly.
Ammo boxes are also good for dry storage of such items as flares.
Don't make a storage tube out of pvc pipe with a screw in plug. In order to be water tight, you will need two big wrenches to open it.
Some of us use welding rod storage containers for our flares. These are popular:
http://www.toolfetch.com/Category/Welding/Welding_Cutting_Accs/Rod_Holders/382-1205455.htm
