Re: Flare storage,
Thinking of a way we can innerline a 2 to 4" pvc pipe with a felt like substance. Any suggestions?
How about this- cut a piece of felt to fit the inside of the pipe, but make it longer than the pipe. Spray the inside of the pipe with 3M upholstery/carpet adhesive, or brush it with contact cement or something. Roll up the felt and feed it into the pipe. Let it stick out past the ends of the pipe.
Take another piece of pipe (wooden dowel?) with a smaller diameter than the first, but longer than the felt, and use that to roll the felt smooth inside the first pipe (like a rolling pin). Probably need to work the ends of the felt to smooth out the wrinkles. You can trim the excess at the ends of the pipe when you're done.
Understand, I've never actually done this, but it seems workable. Might get difficult if the pipe is very long.
If I have a brainstorm I'll let you know.
Whatcha building- a 'comfortable' pipe bomb?
