Fixing bimini snaps
rebars1
The snaps on bimini top are very corroded and some have broken. Is there a way to remove the corrosion? Also, for the broken ones, is it better to install new snaps next to the old ones, or remove and replace them in the same location in order to use the existing male parts on the boats?
5150abf
Re: Fixing bimini snaps
If you can get them out replace in the original position, a pair of side snips works pretty well.
You will of coarse need a snap tool and new snaps, maybe try Ebay for that.
