Fitting a New Turbo Prop
mltitlntd
I am trying to move from a 3 & 3/8, 17" Ballistic to a 3 & 1/419" Turbo I bought on ebay on my 115 Merc Optimax, in an effort to reduce my Rev's. I have two challenges to my efforts to do this:
1. The thrust washer currently in use with the Ballistic is "flat" (it is not inset into the prop hub face, as the hub face is flat). The Turbo hub face is not flat, and assuming I should not use the the flat washer, I do not know which of the inset thrust washers to order.
2. When I place the prop onto the shaft with the existing thrust washer in place, the shaft sticks out a little too far for (1/4" - 1/2") the nut to securely hold it in place. As I don't think the corrrect thrust washer will be any thicker, how do I correct this?
number 2 might be related to the fact that the overall length of the Turbo prop hub is less than the Ballistic. Also, I am not 100% sure the new Turbo is the correct prop for my Mercury Optimax. The hub has "Y 13 1/4" on it, making me think it is for a Yamaha, but I am told that a Yamaha prop and a Mercury prop are interchangeable.
Any help with this greatly appreciated.
Steven
Dhadley
Re: Fitting a New Turbo Prop
Yes, the Yamaha prop like you have will work on the Merc. You'll need a Yamaha thrust washer. You'll also nees a spacer on the aft side if you don't have one now.
mltitlntd
Thanks very much. DO you happen to know the part number for the t. washer, or the spacer, and where I might order these?
Thanks!
Steven
walleyehed
1-800-922-9955....ask for Steve and tell him what you want.
Tell him Kenny sent ya...
mltitlntd
Thanks Kenny. I called today and left a message. I'll look forward to hearing back. I'll call again during the week, if necessary...
S~
mltitlntd
Thanks again. I spoke with Steve at Precision (Turbo) and he told me what to do. I replaced the hub with a particular mercury hub. This allowed me to use the same thrust washer and the new hub was little longer, so no problem with shaft length.
My best to all,
Steven
