Fishfinder Question
Champ186
I bought a used boat that has a Lowrance X85 on the front. I want to upgrade the fishfinder with a better color unit. Does anyone know what unit I can switch to that will let me use the exising Lowrance power and transducer cables? Will any Lowrance or Eagle unit let me do that? I really don't want to run new power and transducers cables. The transducer is thru hull not trolling motor mounted.
John_S
Re: Fishfinder Question
Contact Lowrance:
If you need to speak with a Customer Service agent, please call our toll-free Customer Service line at 1-800-324-1356. Technicians and representatives are available to help you Monday through Friday from 8 a.m. to 5 p.m. CST, except holidays. Lowrance is located at 12000 East Skelly Drive, Tulsa, Oklahoma 74128 USA.
watermellonI
I purchased a used color system on ehay and found Lowrance web site very helpful. (now just need to get the boat in the water)
Boatist
I would call Lowrance. The problem is over time Lowrance had changed plug types many times. Older Lowrance units used 192 khz tranducers and newer units use 200 KHZ frequency. The plug types ahve changed at least 3 times. Some transducers you can get a adapter to change from and old type plug to the current style but if it is a really old unit you can no longer get the adapters.
