Based on other members suggestions I am posting here
Hi all thanks for all the useful info each of you provide.
As title suggests, I bought my first bought for my young family to take my kids fishing.
I picked up a 1987 aquasport striper with an 88 HP evinrude that I was told was in excellent shape. I had a friend of mine who owns boats come check it out for me. He gave the green light. We test rode it , everything was great.
First time I took the boat out the week after, started like a charm. About one minute into the ride , the motor died. Long story short, I thought it was a fuel problem. I . I was told that the boat was losing prime because it was dying after idle for maybe 10-20 minutes. It idled for a while then you can hear it try for fuel and then die. Changed primer bulb and it seemed to be better. I also changed battery due to advice that battery was possibky not good. Honestly I didn't check or ask questions regarding the battery and trusted the repair shop.
Next time out, it had a hard time starting. Had to crank several times, kept cutting out suddenly at idle but not the same as the prime deal. It died very suddenly. I added seafoam and kept trying to run it, adjusted prime bulb to vertical position, eventually it ran and I took it out. However, I noticed that the battery was low from my gps and radio. I was surprised by that but the boat was running so I assumed it will charge and no issues.
I stopped to fish for a while , tried to start an hour later and no juice. I could hear the starter turn but no juice. I had a battery pack so I jumped it. Took it on a ride for maybe 20 minutes hoping it would charge. Shut down and tried again, no juice and had to bump again. I think I bumped it 3 times to get moving again.
When I got off and pulled the boat, I noticed that my hummingbird transducer had some melted spots. I am not 100% sure that it was not melted before I bough it but I do not believe it was.
I am thinking I have a short circuit or something electrical that was causing the problem to start with? The melted transducer and the battery that drains quickly ( not sure if it's considered quick for a new battery to have no juice at all after 5-6 starts)
Any ideas on what the problem could be ? What can I do to fix it ? Help is greatly appreciated
PS- to my knowledge the boat was being used and did not sit in someone's back yard. So gunk build up I think isn't the problem. The previous owner tells me he changed the fuel filter recently.
Is my problem electrical causing the engine to shut down? Two problems that are separate?
Thanks in advance
Thanks in advance
