First time bought need help
Chelseafc
Based on other members suggestions I am posting here
Hi all thanks for all the useful info each of you provide.
As title suggests, I bought my first bought for my young family to take my kids fishing.
I picked up a 1987 aquasport striper with an 88 HP evinrude that I was told was in excellent shape. I had a friend of mine who owns boats come check it out for me. He gave the green light. We test rode it , everything was great.
First time I took the boat out the week after, started like a charm. About one minute into the ride , the motor died. Long story short, I thought it was a fuel problem. I . I was told that the boat was losing prime because it was dying after idle for maybe 10-20 minutes. It idled for a while then you can hear it try for fuel and then die. Changed primer bulb and it seemed to be better. I also changed battery due to advice that battery was possibky not good. Honestly I didn't check or ask questions regarding the battery and trusted the repair shop.
Next time out, it had a hard time starting. Had to crank several times, kept cutting out suddenly at idle but not the same as the prime deal. It died very suddenly. I added seafoam and kept trying to run it, adjusted prime bulb to vertical position, eventually it ran and I took it out. However, I noticed that the battery was low from my gps and radio. I was surprised by that but the boat was running so I assumed it will charge and no issues.
I stopped to fish for a while , tried to start an hour later and no juice. I could hear the starter turn but no juice. I had a battery pack so I jumped it. Took it on a ride for maybe 20 minutes hoping it would charge. Shut down and tried again, no juice and had to bump again. I think I bumped it 3 times to get moving again.
When I got off and pulled the boat, I noticed that my hummingbird transducer had some melted spots. I am not 100% sure that it was not melted before I bough it but I do not believe it was.
I am thinking I have a short circuit or something electrical that was causing the problem to start with? The melted transducer and the battery that drains quickly ( not sure if it's considered quick for a new battery to have no juice at all after 5-6 starts)
Any ideas on what the problem could be ? What can I do to fix it ? Help is greatly appreciated
PS- to my knowledge the boat was being used and did not sit in someone's back yard. So gunk build up I think isn't the problem. The previous owner tells me he changed the fuel filter recently.
Is my problem electrical causing the engine to shut down? Two problems that are separate?
Thanks in advance
interalian
For the running problem, when it falters try pumping the primer ball. If that helps, you could have a bad pump or leaks somewhere. Search and destroy.
For the charging, it's not a very strong alternator - 6 or 9 amp max. You need to see if it's charging, but start by checking if the stator is OK. Need to take the two yellow wires off the terminal strip and measure between them. Should be low ohms, 2-5 or so. Then measure between the yellow wires and ground. Should be high ohms/open circuit. If that passes, time to check the rectifier. Do you have a digital multimeter?
This outboard does not need battery voltage once it's running. The ignition is capacitor discharge and operates by magnets flying past coils on the stator to create primary voltage for ignition. Battery is only needed to crank the motor and get it turning fast enough for the CD to work.
Oh, and the old salts around here will tell you to post current compression numbers. These older V4s are known to break rings. You should have about 100psi/hole with variance up to 15% max (according to the OMC service manual).
F_R
No, it is not normal for a battery to be discharged after 5-6 starts. Well not unless you have to crank and crank and crank and crank some more to get it started.
oldboat1
I think you have a short -- big time. Guessing maybe reversed polarity with one of your accessories (fish finder?) There has to be some heat somewhere, and some blackened or melted wires (sounds serious from here).
It would be good if you could disconnect all accessories -- everything but the engine. Make sure the motor is wired up correctly, and see if the charging system is working.
jimmbo
An inductive ammeter placed on selected wires can help determine where there is draw, and if the alternator is putting current to battery
Chelseafc
Mixing gas and oil at 50:1 on this motor ?
Yes 50-1 oil mix.
I do not have a multimeter but I can get one. I will try to follow some of the steps above.
I am also thinking I have a short, I don't know too much about electrical work but I will try.
oldboat1
For basic wiring issues, I recommend a continuity tester (battery powered probe and light). Do your testing without the boat battery connected. Simplify wiring wherever you can, and make notes.
Chelseafc
Thanks for all your responses
So I had a mechanic take a look. Here is his prognosis
He did some electrical readings while motor was running. He said his multimeter read only an output of 12 V while motor was running. He concluded that the stator was not working and causing no charge.
He also found one of the spark plugs cable disconnected. Connected back and said should be good to go.
Does the stator based on 12V reading sound right?
Also how many hours does it it take to change that on an 87 Evinride 88 SPL?
Thanks all
jimmbo
Well without knowing exactly what tests he did. 12V sounds like a slightly low battery. At what speeds was he doing his tests?
Did he check voltage on both sides of the rectifier? Did he verify the rectifier was good? Changing the stator will require removal of the flywheel. It doesn't take too long
oldboat1
Expensive, though, if it turns out to be a rectifier. Good it was checked out, but might be worth pressing a little more on the stator issue.
Chelseafc
all
he checked at idle and in neutral at a slightly higher RPM.indomt know exactly what readings he was taking.
I suspected it doesn't take too long even based on my very limited knowledge.
He didn't mention anything about the rectifier. I will ask him today to check if he tested it but he asked me to get a stator only. So I assume he either tested and felt it was ok or didn't even test and that is what scares me. I don't want to buy a stator $250 and pay him another sum for it to be an incomplete fix.
So in your opinion, one hour for a mechanic to change the stator and no more ?
Joe Reeves
Trouble shoot.......... Key in OFF position, everything else turned off or disconnected, disconnect positive battery cable from battery. If that cable sparks at the moment you disconnected it AND more-so sparks when you touch that positive cable back to the positive terminal of the battery, then yes... you have a short somewhere.
Assuming you have a tachometer..... does it read accurately or is it erratic, false readings, jumping all over the place, whatever?
Check that the polarity of the battery is okay, that is.... the battery is not installed backwards.... or has been charged backwards (Positive reads to be negative) <--- Yes, that happens frequently.
If the above question about your tachometer holds true.... read on.........................
(Testing Tachometer With Water Cooled Regulator/Rectifier)
(J. Reeves)
A quick check is to simply plug in a another new tachometer as a piece of test equipment. If the new tach works properly and the old tach didn't, obviously the old tach is faulty.... but usually boaters don't carry around a spare tach (see below).
A faulty rectifier wouldn't damage the tachometer, the tachometer simply wouldn't work. This is due to the fact that the tachometer operates off of the charging system and the rectifier converts AC voltage to DC voltage, enabling the charging system. A faulty rectifier disables the charging system, and the tachometer simply doesn't register.
However.... those water cooled regulator/rectifiers that are used on the 35 ampere charging systems (and some others) bring into play a different type problem, and as you've probably found out, they are really a pain to troubleshoot via the proper procedure. There's an easier way.
The tachometer sending/receiving setup operates off of the gray wire at the tachometer. That same gray wire exists at the engine wiring harness which is connected to the engine electrical terminal strip. You'll see that there is a gray wire leading from the regulator/rectifier to that terminal strip, and that there is another gray wire attached to it. That other gray wire is the wire leading to the tachometer which is the one you're looking for.
NOTE: For the later models that DO NOT incorporate a wiring terminal strip, splicing into the "Yellow Wire" mentioned will be necessary.
Normally the Gray wire leading from the tachometer is attached at the terminal strip to another Gray wire which leads from the water cooled voltage regulator/rectifier...... remove the gray wire that leads to the tachometer. Now, find the two (2) yellow wires leading from the stator to that terminal strip. Hopefully one of them is either yellow/gray or is connected to a yellow/gray wire at the terminal strip. If so, connect the gray wire you removed previously to that yellow/gray terminal. Start the engine and check the tachometers operation, and if the tachometer operates as it should, then the regulator/rectifier is faulty and will require replacing. If the tachometer is still faulty, replace the tachometer.
If neither of the yellow wires from the stator is yellow/gray, and neither is attached to a yellow/gray wire, then attach that gray tachometer wire to either yellow stator wire, then the other yellow wire, checking the tachometer operation on both connections.
I've found this method to be a quick and efficient way of finding out which component is faulty.... the tachometer or the regulator/rectifier. It sounds drawn out but really only takes a very short time to run through. If the water cooled regulator/rectifier proves to be faulty, don't put off replacing it as they have been known to catch on fire with disastrous consequences.
