dwco5051
- Sep 14, 2008
- 2,578
Re: First time boat owner..a question needing some help. Plzzzz
I got a better look at you pictures and realized I was looking at the wrong holes. Southkogs is right on the money with his answer. I just figured out the two openings I had in mind must have been for the engine mounting.
Pulling the plug to the live well drain will only bring water into the live well to the same depth as the outside water line. If you are planning on using it you can let it fill and then put the plug in but without circulation or aeration your fish are not going to stay alive all day. Even leaving the plug out there will not be enough exchanges of water to keep it fresh but it may help a little.
