boltbreaker
Thread starter- Joined
- Aug 31, 2004
- 76
I'm doing my first complete rebuild on a 1987 Johnson VRO 40 HP outboard.
I already have the block work done(bored .020 over) and have all the parts for assembly. I had to remove the rods from the crankshaft to remove the crankshaft assembly from the powerhead. When I did, I didn't take note which way the rods were pointing. I know which one is top, and which one is bottom, but have no clue which way to put the rods. I know to keep the rod caps with the same rod, but does it matter if I turn a rod around backwards? Both of the rods have a mark scribed into the piston end to desginate something. I think either I should put the scribe on both sides or oposite sides, not sure which though.<br />I also plan on not using the VRO. I don't know what a VRO is(besides oil injection). I thought just mixing the fuel in the gas tank would be suffecient, until I heard of a "VRO disconnect kit" available from Johnson dealers. Is it necassary to install the "kit" or would I be safe just plugging off the lines? Thanks so much in advance to all those who follow up. Jeff
