javajesus
Thread starter- Joined
- Jul 4, 2009
- 42
Ok, so with all of your help here, I finally was able to get the Aztec out on the lake for a day of mostly trouble free fun. The engine is an omc with a 77 electric shift. After running hard-ish across the lake, we pulled up to a friends dock to visit for a few minutes, then went to take off and no start. Would crank, but not catch. After I pumped the choke a couple of times it would start and idle at higher than normal rpms. After a minute it would settle down then start to surge. low to high rpms. if I put it in gear it would die. He suggested it might be a fuel pump. The other things that might be worth mentioning are that cold starts are difficult (have to pump the choke arm) and after running then shuting off gas will drip from the accelerator pump (i think- left side of carb, small rod coming out of it) about 12 drips and thats it. I know, not safe need to get that fixed pronto) So, any help here would be appreciated. If it is the fuel pump, the engine is a 350 gm, can I use a standard mech pump, or do I need to buy a marine one?
