First deck replacement, I have questions
briangcc
If carpet isn't in your plans I would consider something along the lines of SeaDek (there are other brands out there as well). Going to be expensive so be prepared on that part (my swim platform was around $5-600 all said and done if I recall correctly) but well worth it in my mind.
76SeaRay
Answering the question above. Changing from OMC to Alpha One cutout meant completely covering the opening but since I was replacing the transom plywood, that wasn't really a problem for the new wood. The bigger issue is layering in fiberglass on the outside of the hull to fill in the hole and then gelcoating it. So, not bad at all if you are doing the whole transom. I have the factory tool for cutting the keyhole and drilling all the holes so that was pretty straight forward. Biggest problem there was saws getting dull quickly.
