Fire Extinguisher installation and locations on 2152 Trophy WA
redlegtex
I am a new member. I want to install several fire extinguishers on my Trophy 2152 Walk Around. I am asking for recommendations to best or preferred locations. I was thinking of mounting one on the captain's seat pedestal. Any suggestions and maybe pictures would be greatly appreciated.
JamNJ1955
Re: Fire Extinguisher installation and locations on 2152 Trophy WA
Here is where I have them on my 2002WA
Hope this helps!
John
redlegtex
John: This helped. Thanks,
Alan
redlegtex
John: Did you mount the brackets with screws or bolts? It looks like the two could be aligned with each other on either side of the bulkhead.
Alan
Monterey10
I've read over the years that (generally speaking) you want an extinguisher inside the cabin and out on the deck. I believe the thought is to be able to use the extinguisher if the fire is between you and the cabin door.
JamNJ1955
Alan,
I will check (screws/bolts)in a few weeks when I remove the winter cover. Mine came with the extinguishers mounted.
JamNJ1955
Yes, Same bolts hold both extinguishers.
