Finicky Fuel Gauge
Jns1981
'87 Cobia 189 Monte Carlo... its a junker, but great fun on the Hudson!
The past two trips the fuel gauge has been odd... it randomly reads empty for a bit--then "wakes up" and reads accurately.
I'm new to anything electrical in regards to boats. Engine/mechanical things I can handle... also, its embarrassing-but I don't even know how to find the sending unit to check/problem solve.
Any advice on where to start would be amazing. I looked at the gauge behind the dash and its a plate of spaghetti!! The wiring is insane!
clean your connections at the fuel sender and at the gauge.
legalfee
Usually the sending unit is inside the tank but the terminals are on the outside on the top. There is ground and sense wires. As Scott says clean the terminal connectors and put dielectric grease on them. The sender should read 33 ohms full and 240 ohms empty.
Jns1981
checking the unit makes sense.. im baffled as to where it might be. Its a junker.. it has a board/floor over the old soft floor as a quick/dirty fix... i realize i need to remove the "2nd floor" but should the inspection port be easy to find? is it typically under the carpet?
its an 18ft bowrider with a ski locker.. assuming the port would be between the ski locker and the engine cover? correct?
Lightwin 3
Where is the tank? If it is in the floor, the sender will typically be near the rear of the tank.
Jns1981
i believe the tank is in the floor. is there always a port for the sender unit?
legalfee
This is a typical fuel sending unit
Jns1981
If an access cover isn't present, is the only other solution is to cut one in order to reach the sender unit?
