Sunsetrider
Thread starter- Joined
- Jun 12, 2011
- 299
Re: Finally got mine!
GA - perhaps I have misinterpreted the purpose of the configuration of the sides of this boat. Looking at the pic below you can see the indented lip along the bottom of the inside vertical surface of the gunwale. You can also see a darkish line running along the length of the boat near the junction with the deck surface. That line is in fact a channel about 1/4 inch wide and about the same depth, and is located directly below the aforementioned "lip." I was thinking that a length of 1/4 inch ply would screw into the lip up top and snuggle into the channel below. I would further secure the bottom edge with a triangular "baseboard" trim along the deck against the sidewall which serves to provide an angled transition for the vinyl deck covering. It is this alignment of lip and channel that is tempting me to consider sideboards. Otherwise I likely wouldn't bother. But it seems as if it was meant to be . . . .
