Re: Finally began my summer project and I am already confused...
Its very do-able in that time frame but the snag always seems to be side projects and getting off track with silly stuff, save all the cosmetics until after the major elements are back together, the last thing you want is having the internals exposed to bad weather.
Stringers and transom are the big two.
Then the cap and or deck.
You need a bunk trailer if you're removing the stringers...or replace one, then the other, that will retain the hull shape.
Another big time saver is polyester resin, 20 minutes vs 24 hrs for epoxy.
If you're doing a ply transom and stringers get some PT ply now and let it dry out if its still green. If its damp the resin will not take.
Kiln dried external PT is good.
But first you have to gut it, get some big trash bags.
If the stringers are dry you win.
How is the transom?
I know you jumped on it but that can be misleading , if its wet its shot.
How is the transom?
