Filling block with antifreeze
cwrhyne
1999 Volvo Penta 5.7 GS DP-SM
I am winterizing this weekend and after reading all the stickies I am going to drain all the water from all the plugs and hoses per the owners manual. I am choosing to fill the block with antifreeze even though I know I don't have to but because I believe in being over prepared.
My question is where do I fill? Both thermostat hoses? remove thermostat and fill there too? Is there a procedure on here somewhere for this?
Thanks in advance.
alldodge
Remove hoses from thermostat housing, larger lower one first and fill. Reinstall and remove smaller ones and fill, this will fill everything including exhaust manifolds.
Being a VP make sure to drain the intake manifold before filling
cwrhyne
Excellent. Exactly what I was lookin for.
Drain manifold from here?
enginesilo
Not hijacking, but do I need to drain this on a 5.0 GXI-B as well? Never saw anyone mention draining the intake manifold before.
alldodge
Yes, or at least look for a drain plug
VP motors don't use the hose which connects the intake to the top of the circulating water pump on SBC. The places where the hose would be attached are plugged, so the plug needs to be removed to fully drain the intake
cwrhyne
While I'm in there, how often do thermostats need to be changed? Every other year? Every 3? I've never had a problem and I'd like to keep it that way. 25 bucks is pretty cheap insurance.
alldodge
The one in my 1995 Rinker is original and still works as designed. I use the, if its not broke don't fix it for those kinds of parts
89retta
Disagree on this . The answer is no as you have a fuel injected motor and there is no drain on the manifold
