Ficht cruising surging problem
Sonsy
I have a 1999 ficht 225 ina sport craft cuddy 222 offshore has very low hours and been kept inside the whole time one owner and recently I've done some work to get it running better because it was not used much before I bought it. Xd100, new plugs, waterpump, fuel sep, & filter. What happens now is when I first run it it's starts right up idles fine and runs fine but while at speed between 4-5000rpm it will go in and out, not sure if surging is the right word but it does it lightly then will drop below 3000rpm and stay for 45 seconds then go right back and if while below 3000rpm i floor it, it won't go past 5000rpm unless I pull back and let it cruise for a min and it will jump back. Sometimes like today it didn't do it barely at all but once real light. I have not done thermostats and they haven't ever been done yet on this motor also I'm going to decarb it with some spray tuner but I don't think that will fix this issue. If anyone knows what kind of thermostats I should use that's would help me also I've heard to use etec. Can I find them online and do them easily.ive done everything else on my previous motors but this is my first two stroke!:) love the power and fuel efficiency of this motor I know the stories but I had a great deal on it and am going to give it lots of love and enjoy it for now since I don't have a lot of extra money to spend my goal is to get her running perfect and feel confident I can take it down the intercostal of Florida and also go out in the gulf fishing and not feel stressed about it crapping out like my last boat. Thanks guys this is my first post I like the layout of this forum a lot!! Cheers mates
merkdawg0084
Ok,,word of advice. I read your looooooong post. It’s nice you’re excited about a new motor and glad you found this forum., It is a great forum..Yes you can find thermostats.. You just have to research your engine. These guys are here for their knowledge not a parts look up guide. Keep your questions short and to the point and that might help you get a reply.. Some of these gentlemen are older and they don’t want to read a book.. Lol. Hope you don’t get upset about my reply.
Auxlarry
epc.brp.com
Welcome to the board and listen to the experts here. Most of the guys here know their stuff and will help you if you listen to them.
Go to the BRP parts page and look up your engine by model number. It will give you part numbers and break downs of your engine.
jakedaawg
Post complete model #.
Any flashing lights or warning tones on system check guage?
Did you index the plugs? What plug did you install? I believe this may be one that calls for a different than original plug. Also there was a pinned vs. Unpinned head thing. Jeez, it's been awhile since one of these was still alive.
Have you done a compression test?
Do you have a manual? You will need one. There is not much support at all for these motors. They are pretty much disposable.
Do you have fuel pressure test gauges and fittings? You will need them.
Do you have access to the software? Even if you do I dont think you can get injectors. Emm is nla also. Used to be a couple guys redoing them but I think they quit.
It will be much better in the long run and most likely short run to just give up on this without spending anymore money and buy something that does not say ficht. They really are a case of throwing good money after bad.
If someone said there were 5 left running it would not be a big exageration.
