Fiberglass v epoxy resin for decks
carpenterken
My cousin and I are redoing the deck on his 19' Slickcraft. The stringers are all glassed in. We need to install the deck, pour the foam, then seal the deck.
When we seal the bottom side of the pw, do we need fiberglass cloth, or will resin only work?
Then on the top side, should we use epoxy or fiberglass?
I've read that Aero Marine is a good place to get the product. I do not see glass resin on there site, only epoxy resin.
How much will it take to cover a 65 square foot area?
Thank you.
Ken.
Woodonglass
Re: Fiberglass v epoxy resin for decks
My recommendation is to use 1.5 oz CSM on the bottom side of the deck and I would use poly resin NOT epoxy. Poly is about half the price so you get more bang for your buck. Epoxy might be a little easier to work with but not that much. Resin without Mat or Cloth is like a car without tires. www.USComposites.com is a good source. On the top, I would use 1708 Biaxial Cloth. It's a combination mat/cloth and very easy to work with. A general rule of thumb for coverage is 6 oz of resin per sq. ft. Based on that I would think 3-4 gals should do the trick. Mat and cloth are sold by the yard and come in 50 inch width's.
I'm just sayin...:D
carpenterken
I'm just sayin...:D
Thank You!
brainula
dear carpenterken,
When you estimate 6 oz of resin per sq ft you are figuring a single layer of csm or 1708 right? So if one had multiple layers (like a transom) one would simply multiply x number of layers, yes?
WIMUSKY
brainula, welcome to the forum.
Please pay attention to the red box on the bottom of the screen when replying to old threads. This thread is considered "dead".
12. Please do not post to threads that have been inactive for more than 3 months UN-LESS you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread. This is considered a hijack. Please start a new thread of your own.
Thanks!
