few swap questions
lotz
i have a 1985 imperial cuddy cabin, 20', that had a locked up 3.0l in it. i got the motor out and started tearing it down and found a lot of water in the oil, i would like to put a v8 in it so i will be looking for the motor and outdrive for that over the winter, so my question is if the backing plate for the v8 and 4 cyl outdrives are the same. i have to redo the transom and some of the stringers so now is the time to do the swap since ill have to redo the motor mounts anyway.
matt167
Re: few swap questions
The 3.0L has the same bellhousing pattern as the SBC/BBC V8. So I guess it's possible you can use something from the 3.0L. Drive ratio's are all wrong for a V8, so you'll need an entire new outdrive. You'll want to get a V8 donor boat, or at least the complete engine/ outdrive package from 1. piecing it together won't be cost effective.. Also check your hull ratings to make sure it can handle the extra weight/ power
lotz
where should i be able to find the ratings at as far as power. the tag on the inside of the boat is so faded that i can barely read it, and i havent been able to find much info on the boat itself online.
matt167
The hull tag is where the rating will be. Possibly someone else will know, but Imperial has been gone for a while, so they are not around to help anymore. The holding company that owned them may still exist and be able to get records. That company was/ is ASI..
I think those boats only came with 470's or the 3.0L's.. My dad had a '84 VC230. Nice boat, but he let it go cheap when the 470 started knocking
