Feeling Dumb about70 Merc Tilt??
madmans
I am new to this forum. Nice bunch and loads of info. Now i just bought a thundercraft with a 70 Horse 700 Mercury outboard. It runs well. I cannot figure out how to get the thing to tilt up. ??/ I had 4 other guys lookin at it and we all gave up and just drank some Budweisers. Please Help
j_martin
Re: Feeling Dumb about70 Merc Tilt??
Keep drinking the Buds, and eventually you'll tip over and the motor will look like it's tilted up.
airframer
need a little more info. is it electric or manual?
MIKEY*2007
mate if it is electric it will have a pump of some type on it early mercs don,t have power tilt,i have a 68 100hp it doesn,t have one ,lift by good old man power. what year is it .look on motor if it has two rams bolted from mid motor to the engine bracket with no sign of hydraulic lines it has not got it. a manual lift will have a latch on side of motor near transom. to lift motor it has to be in neutral lift all the way up and move latch to downward direction to lock rest motor on transom and there you have it.let me know how ya went aussie mike .
arjay2008
If its a hydraulic tilt check that all the electrical contacts are clean and that the adjustment screw is positioned correctly.
Madmans, I'll bet it is manual, and you did not put the throttle handle into forward, to release the reverse lock.
Am I right?
