edit-Insert
Thread starter- Joined
- May 22, 2017
- 34
I have acquired a second FD-11. Both motors go through combustion cycle feeling great. The first I got is a complete mess. Stuff missing bushings worn, just a nightmare. However it had the power. It's only fault in the process of doing its job was showing symptoms described by the manual as a failing bell crank.
The new to me one, is in far superior condition. But the power just isn't there. Which I think should be easier and cheaper than trying to find a gearing gremlin.
My thought was to take the combustion part of the motor (power head? Sorry don't know correct terms) from the older to me motor and put it on the new to me one.
Old motor; no reverse, prop and shaft moves about 3/4-1" when I pull on the prop, the tabs for throttle and steering controls are gone. Terrible camo paint job.
New motor; only issue is low power.
How hard is it to change. Is there a better option? I have no private garage, no stand and no way to hook up hose. On the other hand I have a cd with manuals for 30+ years of Johnson Evinrude motors on it. Got it for 15$ on eBay. It's about 10 different PDF files.
