Fast Help needed on Alpha 1 Sterndrive Mystery 0-Ring Found
The Hot Tamale
Hi, I am headed out on a trip tomorrow for the week. Of Course I had a boat problem that caused me to remove the sterndrive and replace the ujoint bellows. While that has not been fun, it moved along well.
What I am confused about is reistalling the Stern Drive. I found an "extra o-ring" that is thin and about 1.5 in I.D.?????
It is not one of the three already on the splined shaft, they are accounted for. Also, it is not the o-ring for the water passage way.
I have no idea where this came from? It was on the ground after removing the drive. I have searched everywhere and in the manuals and cannot for the life of me figure out where it came from. It fits too loosely on the splined shaft, I thought maybe some mechanic put in on just before Ujoint on splined shaft. But I see no reference to do this anywhere. I have checked all videos, posts, and manuals and it just does not make sense. But there it is!!
Can anyone help me quick?
Also, I have slight tear in gasket now. I am going to put some formagasket there to be a temp fix since it is sunday and I can't get any parts. Does anyone see an issue with that? I should have purchased a new gasket for this job but forgot.
I just need to use it for a week or two, then should be able to get back in to do it right.
The mystery "o-ring" is my biggest problem. Thanks in advance for your help!!
Re: Fast Help needed on Alpha 1 Sterndrive Mystery 0-Ring Found
Ayuh,... It's an $8.00 gasket set,... get 1 at Napa tomorrow, 'n put it back together then...
That means yer reusin' all the o-rings too,.............:rolleyes: :facepalm:
stonyloam
Best guess is that it goes on the water passage on the port side of the bellhousing. bond-o +1 get new gaskets or you could be asking for trouble.
The Hot Tamale
Thanks so much Bond-0 and Terry-
I am now totally convinced on the gasket, I'm not going to take the risk. I just wanted to try out the other work i did until I get the gasket.
I am still not sure on the 0-ring though. I only had the bell housing off and far back enough to get the new u-joint bellows in. It was very difficult to do, but I did not want to take apart shift cable/boots and exhaust boots at this time. The Gimble bearing seemed fine.
So this mystery 0-ring is still out of no where. Since I know I have the Three that I need on the spline shaft I think I am good. I read a post that back in the day on older drives, there was a "loose o-ring" at the u-joint. Must hit the gimble bearing or something. Maybe the last mechanic thought it was needed, but I don't see any references to it at all anywhere.
I wonder if you have any other ideas? or just let it go? Again, I am scratching my head since the only place that I can think of that it came from is when the spline shaft dropped down after I pulled the sterm drive. It is that loose that i just slipped off? Again, the three that are supposed to be there are.
Thanks again for all the help, I am new to this forum and it is great to be able to ask questions from the experts. Thanks again.
SeaRayboater95
I'm wondering if its the raw water supply indicated by the yellow arrow?
ktbarrentine
MHO.... If you have all the o-rings, gaskets, hardware, etc that is shown on your exploded diagrams, then go with that... My theory is that the previous owner had all those "extra" parts (i.e. The "extra O-ring) that one gets in bell housing gasket kits these days (and pump kits, for that matter) that he just threw it in there for "good measure". I have a collection of those spare parts on a nail on my shop wall... maybe I can use them on my lawn mower....right Chris?!;)
