Faria Depth Gauge not working
deeman7777
I have a Faria digital depth meter which is not working.
I can cycle through the screens and when I get to the "depth" screen which should show the depth it shows flashing 00.0 and beeps non-stop.
I have not double checked the transducer but I have to imagine it's secured properly to the inside of the hull.
I feel like I have reset the meter several different ways, but I'm not 100% sure.
Could any of the other screens (depth alarm, etc) cause this error? Any other suggestions to fix this issue OR to point to a faulty depth meter?
Thanks!
dingbat
Thanks!
A flashing depth screen is typically a bad transducer
deeman7777
Direct reply
Flashing 00.0 with continuous beeping is most likely a transducer/signal problem, not the depth alarm setting. The alarm can make the unit beep, but it should still display the actual depth.
Check the transducer mounting, connector, and wiring for a loose connection, corrosion, or damage. If it’s a shoot through-hull transducer, make sure it has good contact with the hull and hasn’t shifted.
Also check the gauge’s power and ground connections for a solid 12V supply. If everything checks out and the gauge still shows flashing 00.0 every time you select depth, the transducer is the first thing I’d suspect. If a known-good transducer produces the same result, then the Faria depth gauge is likely faulty
Thanks for the advice, I will double check the transducer.
