F16 Alumacraft boat restoration
FirehawkNS
Hey iboats, since I have been reading the forum heavily over the last couple of months for information I thought I would post up my project.
I inherited a 16 foot Alumacraft from my late grandfathers estate when he passed. This boat holds great memories of my Grandfather and I fishing the weekends and summers away in the 80's and was the source of many fish fry's.
Growing up we kept this boat at a Weekend lake house our family had, but in 96-97 the family sold the house off. My Grandfather brought the boat home and backed it into the woods behind his house, uncovered and open to the elements and there it sat until 2009 when I pulled it out after his death.
I decided I wanted to try to restore it and have it on the water again. It's not much, but it's been a fun little project so far (although not a lot has been done yet). I hope with this thread I can get more information on this from people that may know more information on this beast as my parents don't remember a lot about the boat other then they believe it was bought new.
I don't know the year of the boat, but after researching the SN of the motor and searching on this forum I have found that the motor is a 1978 Mercury 200 (20hp). I am still having trouble finding any info on the boat, but here she is right after pulling it out of the woods and under a shed at his house.
Inside had small plants and a nice root system through out the dirt and leaves
Once getting new wheels and tires on and getting it to my parents house where I have access to better equipment. Once there Dad and I pulled the motor off, cleaned it out, ripped the rotten wood out of every section, and pressure washed the whole boat. That was the extent of my working on it last year as time became scarce.
So I finally got back on it over the last three weekends. Since I was working by myself this day I had to figure a good way to get the boat on and off the trailer by myself so I could work on the trailer.
Straps worked well.
Condition of some of the trailer parts after taking them off.
Most bolts were cut off, although a few were taken off fine after some PB Blaster.
Under the rust....more rust.
FirehawkNS
Re: F16 Alumacraft boat restoration
After 2 days of sanding/grinding and new Bunks cut out as the stock were crumbling in my hands.
And the trailer is done. 8 coats of Rustoleums new Primer/paint combo and 4 coats of Rustoleum clear.
Dad has been using the boat to hold his ladder collection.
The next weekend it was time to see the big budget item, the motor. I never realized how expensive these little suckers were. I know now. :O Doesn't look too bad at first glance.
FirehawkNS
Inside the cover I find wiring failing apart and almost 15 years of dirt dobbers and other bugs inside. The dirt Dobbers scare me, but luckly my grandfather was smart enough to plug a lot of the holes going into the block.
Most the wiring looks like this:
Luckly I was able to save the external wiring harness since it is a $200 part. I wasn't able to save the internal one, but new ones are around.
The lighting stator (thanks exploded diagram for the names of parts) wiring was shot so I soldered new wiring on to try to save $100 or so dollars. Not sure if it will work, but trying to stay on the chep side of things until I know if the motor works.
FirehawkNS
Silly 6 image limit. lol
The motor always ran perfect all the years it was used up until it was parked. Every session it fired right up, so here's hoping it does yet agian. This weekend I got in the internal harness, tiller handle, spark plugs and wires, and water pump. The Venturi broke off the carburater so I figure I will have to buy a whole new unit instead of rebuild since I don't know if one comes in a rebuild kit. If anyone knows and is reading this long post, please let me know.
last this past weekend was to run wiring for the lights and horn I plan to mount up front. Not really doing anything else to the boat until the motor fires up.
I have also cleaned out the black paper like stuff in the picture above and have it ready to redo.
jspano
nice work on the trailer!!
the boat seems in good shape
your grand dad and dad would/should be proud
it's hard to keep a good tinny down
moonfish
I have the older 14' version. If I were you, I'd buy an older 30 some horse OMC. That motor looks like it needs a whole lot of work to me and even if you got it fixed, it is kinda small for that boat.
boatflipper
Looks like you are moving right along!
It is amazing what a little effort can do! (referencing the trailer)
I too would keep an eye out on the local craigslist for another motor. If you find one in running condition and buy it, that will get some pressure off with trying to get that merc goin. That way you can tinker with the merc at your own pace.
Keep us updated and keep the pics comin!
FirehawkNS
I looked around at motors and I have a lot of trouble finding anything nearby for under $1200 or so. My brother-n-law is helping since he has had more experience tearing down marine motors and so far from us looking at it he doesn't think it's in bad shape once we got the wiring and surface stuff cleaned up. Could be wrong though, have to cross that bridge when I get there.
I would have liked a larger motor (I always go for more HP in my motorized items :D ), but really want to see how low I can keep this build money wise. At least in the beginning. Maybe restore the motor for a good deal and sell it to put toward a larger motor. Time will tell.
ezmobee
You have certainly rescued that one. Great work so far. Good luck with the motor! Post any of your motor questions in the Mercury outboard repair section. The mechanics don't seem to spend too much time here in resto.
