imported_Warren
Thread starter- Joined
- Apr 7, 2003
- 261
87 Evinrude 15hp, O.K. I replaced the water pump, did the thermostat(the seal didn't seem to fit right though), and did the OMC carb rebuild kit, after I put all the parts I could find into the carb I had extra parts. 3 button looking things and 1 little clear plastic cup looking thing. Anyone know what these are? and if they were important? Also I replaced the thermostat and had to pick out the old rubber seal from inside the housing, there was no corrosion and no rust but the ring was a real pain, took me an hour before I said good enough and just put the other one in that came with the kit which didn't seem to fit right, is this normal? I haven't started it up yet waiting to hear from you guys first. Also when I pulled the motor out of the trash can I saw a little oil dripping out of the prop bearing housing, did I need to put gasket sealer on that before re-installing it? Also I pulled the fuel pump off and gave it a yank. How strong should the gas squirt out when you do this? Not sure if I need a fuel pump re-build also....Thanks for the help.......Warreb
