Extra Bilge Pump
Captain of the Double G's
I always have an extra bilge pump with the alligator clips and extra wire.
I know others have probably mentioned it before but this is a reminder.
Sometimes I bring it along on friends boats or when on a different vessel, its cheap insurance
dingbat
An exercise in futility….
A portable bilge pump is not going to keep with a hull breech. If push comes to shove, time would be better spent sending a DSC and preparing the crew to abandon ship.
The obvious question…why carry a wired bilge pump and length of hose around in your dry bag when you could simply install the pump in the hull proper and call it good?
OK, truth be told is I have probably been watching too many marine salvage videos instead of messing with my boats. :)
arks
It certainly doesn’t hurt to have an 12V emergency pump available.
I’ve had one in a marked tote bag in my cockpit for 20 years, and it’s been used twice. All my slip neighbors know it’s there, and one night one of them got a call from another who hit something a mile away and had developed a bad leak on his 30 footer. Even though I wasn’t aboard, he grabbed my pump and took off to help. My pump (along with the built-in pump aboard) worked well enough to get him to the slip, where they got a big 120V sump pump that got most of it out quick. Whatever he hit bent one of his inboard shaft struts, causing it to leak into the hull. He hauled it the next day and had it- and his hull- fixed.
alldodge
For years I wanted to setup the same thing but for a different reason. If it gets real hot and stays that way with no rain the fresh water lake gets so warm it's like taking a warm bath. So I thought about hooking up a bilge pump and about 15 ft of hose to pump cooler water up to the top. Never done it and with all the rain we get off/on it's not an issue this year
so you may have saved a life
roscoe
I have two installed in my 16'. Learned my lesson when I sunk my 18' at the dock in an all night storm.
One is hooked up to the main battery via a switch on the dash.
The other is on a float switch connected to the house battery.
The secondary pump worked well and kept the boat empty when a freak thunderstorm hit. It only rained for 4 hours, but got 5+" of rain. The winds hit 44 mph and 25 sustained for hours. Boat was stuck on the dock for 18 hours before we could get it on the trailer. Had 3' waves for a while, then 2'ers for 8 hours.
Video from the next day AFTER the waves calmed down.
You should have seen her bouncing in the middle of the night.
Resort owners thought it might end up on top of the dock, as that's happened before, to a nice Ranger bass boat.
View attachment IMG_0240.mov
froggy1150
Ensign
I run 2. A small 5/8ths and a larger 3/4 outlet (500/1200 gpm) i think. The small one turns on first for normal usage and the bigger one is backup cuz I have a omc with the big 2' square rubber seal.
redneck joe
dad hooked up an poum and kept a hose long enough to drop about 6 foot and the other to reach all the boat. We would do a washdown before pulling the boat out or during the camping trip.
Mc Tool
Yeah and for hosing all the blood and scraps into the bilge so the bilge pump can dump it over the side ....then just chuck the bigger bits over the side .
Mc Tool
You'd be better off with one of them disposable ally turkey roasting dishes 🙂
dingbat
Missed 1/2 box of squid in the bait well on day. Found it the next weekend…
I bet putrified squid stuck in the screen in the base of the bilge pump would smell just as good after a week or so…lol
First accessory I installed was a 4 gpm, 60 psi washdown system. Hooked up to a cockpit shower and a 25’ washdown hose. Blood and guts get hosed out the scuppers
Mc Tool
Huh , I dont have scuppers and Im pleased about that coz everything I own would fall out them .....cept my fish coz they are way to big to fit out scuppers 😆
I wonder how they got to be called scuppers. I have often heard that something got "scuppered"....usually a plan or that something "put the scuppers on that " when whatever it was wentt its up 😁
Grub54891
Overview
The word scupper comes from the 15th-century Middle English word escopier, which traces back to Old French meaning "to wash, clean, or to bail out/empty water". Over time, the linguistic root evolved to describe the physical drain hole itself rather than the action of clearing water. [1]
What Scuppers Do on a Boat
    • Drain water fast: They let rain, ocean spray, or crashing waves drain straight off the deck and back into the sea using gravity.
    • Keep the crew safe: Removing standing water stops the floor from becoming dangerously slippery.
    • Protect stability: Draining extra water prevents the boat from becoming heavy, sluggish, or prone to capsaking.
    • Stop backflow: Many scuppers use flaps or one-way valves so water can flow out, but waves cannot rush back inside. [1, 2, 3, 4, 5, 6, 7, 8]
A short video showing the structure and practical function of scuppers and drainage grates on a ship's deck:
Scuppers and Drainage Gratings by If I were a MARINER on YouTube
2m
11 months ago
YouTube · If I were a MARINER
If you're working on a boat right now, would you like to share what kind of boat it is or if your scuppers are letting water back in? I can help you find the right fix or valves.
  • Reddit·r/explainlikeimfive
    how do scupper holes in Kayaks work? Why can boats and ships not ...
    Jun 24, 2023 — Scuppers in ships are above the water line at the level of the deck. When a wave comes over the side, or water accumulates on the ...
  • Wikipedia
    Scupper - Wikipedia
    Ships have scuppers at deck level, to allow for ocean or rainwater drain-off. · Buildings with railed rooftops may have scuppers t...
Show all
AI can make mistakes, so double-check responses
