On my project boat the transom is 19" deep rather than the standard 20" deep. The cavitation plate of the motor is therefore 1" below the bottom of the boat. How does that affect performance?<br /><br />If I do the USCG calculation for max HP for the hull, that 1" reduces the USCG reccomendation by almost 50% vs the reccomendation for 20" transoms! That 1" difference relegates the boat to motors that are appropriate for 15" transoms! It seems the USCG is a bit draconian on this issue. Thoughts?<br /><br />The transom (where the motor mounts) is 5" lower than the rest of the stern so there is a lot of room to add another inch to the transom and therefore almost double the USCG max HP rating for the boat. Is it a good idea to extend the transom up by that 1"?<br /><br />If it is a good idea to make the transom 20" deep, what is the proper way to do it without removing the existing transom that is perfectly sound and strong? I know a jack plate can raise the motor but the transom will still be 19".<br /><br />The stern of the project can be seen at the URL below.<br /><br />Thanks.
