Extended shift handle 1976 25 HP
iam2sam
Hello. I have a 25602E Evinrude manual everything (which is how I like it for this boat.) I have no trouble reaching the tiller and throttle from my seating position, but the shift lever is a bit of a stretch (opposite side of the motor.) It isn't critical, but I will have a long reverse at my customary launch site that would be easier to negotiate with a more convenient shift method. The lever has a slot with a round hole near one end, which I imagine is where linkage for a console remote shifter would attach. I'd like to make a short (12 - 18") extension handle to attach to the lever using this slot. Anyone done this? Anyone know of any standard aftermarket extensions that would fit, or at least a fitting that matches the slot in the lever (maybe parts for the remote shifter set-up) that would work? Other ideas? Thanks.
Chinewalker
You should be operating the tiller with your left hand, sitting on the starboard side of the boat. Sitting there gives you access to all controls. When going in reverse, shift yourself to more or less face the motor, operating the throttle with your right hand and shift with your left.
F_R
Honorary Supreme Mariner
If there is some reason you just can't sit on the starboard side (or don't have use of your left arm??) to answer your question yes there was an accessory that unofficially was called a "Shotgun Shifter". With it, you slide the throttle twist grip fore and aft to shift. It wasn't very popular and might be difficult to find, but just sayin' it does exist.
F_R
No Title
Shotgun shifter kit
