- Apr 17, 2002
- 71,543
Re: Explain bearing buddies to me...
Ayah.........<br />And, I've Fixed Alot of trailers with Blown Wheel Seals, That Leaked Water into the Inner Bearings......<br />It's the head of Air, Between the Bearings, That holds the 3psi,+ keeps everything Where it belongs.........<br /><br />In a Perfect World, That quote is exactly Right........<br />But, Contaminants Will find their way In,+ Grease Dries Out....<br />And,<br />A Hub that's Literally,Physically Packed with Grease,<br />Is a Waste of Good Grease.........."The Bearing Buddy® system maintains a constant pressure of 3 p.s.i. on the grease inside the hub. Since the hub is always full of grease (with proper maintenance) there is no need to repack your bearings."
