exhaust manifold
barnyard
1995 350SBC wet exhaust. Upon inspecting manifold,
found metal worn away on top slots with partition maybe 1/16" deep. Is this a problem? one gasket, two gaskets or replace?
Scott06
yes has to be flat . you may be able to resurface them with a belt sander, bastard file, or if you have access to machine shop they can mill them down.
Alternatively if you are not is fresh water and they are of unknown age better off replacing with good OEM merc or Barr manifolds
1995 would be the cheap mercruiser manifolds (relatively speaking as the price tripled in the last 5 years)
