F_R is right that you shouldn’t be reaming the jets, but I’m a big believer in some careful soaking and poking. Disassemble the carb and soak in lacquer thinner or something that cuts through fuel varnish, then use a soft wire or piece of monofilament to run into and through every opening. Finish with carb spray, using the plastic nozzle to again hit the small holes. Take off the domed cover on the top before soaking and thoroughly clean out the idle passages underneath.
[Edit: BTW, you could have the broken point of a needle jammed into the orifice in the carb body -- might not be aware of that without taking the domed cap off and looking. It's a good idea to test fit the needle with the cap off so you can see that the point properly fits the opening -- that the opening wasn't damaged by a PO.]
