Evinrude VRO Disconnect
jerryjerry05
I'm working on a Evenrude swap An 88 for an older 110???
The Vro was disconnected a long time ago.Still has the VRO pump(gonna change that over too).
There are oil lines??? Small hoses (4) from the intake manufold to the powerhead.
Should these be blocked or replaced?
They are cracked and broken.
I wonder will this contribute to sucking air and not run right???
Thanks,Jerry
You can send me a PM as I'm gonna do this first thing in the AM and need to know,before I wrap it all back up????
Thanks!!!
boobie
Re: Evinrude VRO Disconnect
The small lines are for the oil recirculation system in the p/h. If they are capped you could foul plugs at idle. Replace the lines.
jerryjerry05
Oil recirc??? VRO is unhooked.
I was gonna replace as getting the tiny plugs would be a bugger!!!
Thanks.
Cady8special
I had that problem a few weeks ago-- the angle is too sharp for those old brittle lines. Didn't seem to affect performance too much, but that oil gets all over. It takes unburned oil/gas and rather than spewing it out in the exhaust, it gets re-circulated into the carbs.
boobie
Mtrs have had recirculation systems on them since the 50's and they have to function to make the mtr work properly.
emdsapmgr
You are correct, the recirc systems draw excess fuel/oil from behind the reed boxes and recirculates it back into the engine for combustion. It helps the engine idle better. If the hoses are cracked, leaking-it is messy and affords the opportunity for extra air to get into the fuel system. That contributes to a lean condition-probably best to repair those tiny hoses sooner rather than later.
jerryjerry05
Got the answer I needed.Thank you very much,emdsapmgr !!!
WILL result in a lean condition!!
I specialize in Forces and and I'm working on my neighbors Everude!!
Same systems just a bit different!
Thanks again.J
