Try that first. If not successful, the usual problem is corrosion buildup around the outside of the upper swivel bushing and the aluminum surrounding it. That bushing is stationary (does not move) and getting grease into the problem area is virtually impossible without taking it apart and scraping the corrosion out. Happens way often in salt water motors. Seen it, done it many times. Take heart, it isn't as bad a job as it appears.
