Evinrude steering bracket grease prob
RetSenc
Working through first engine project, steering bracket grease is old, stiff and waxy. Best advice for removal? Its an '86 30hp (E30RCDM).
GA_Boater
Welcome.
Use a heat gun to warm and soften the old grease and pump grease in until it comes out the top and bottom of the swivel.
F_R
Honorary Supreme Mariner
Try that first. If not successful, the usual problem is corrosion buildup around the outside of the upper swivel bushing and the aluminum surrounding it. That bushing is stationary (does not move) and getting grease into the problem area is virtually impossible without taking it apart and scraping the corrosion out. Happens way often in salt water motors. Seen it, done it many times. Take heart, it isn't as bad a job as it appears.
