Hi Guys<br /><br />I need some help, i'm running a 1991 50 HP 2 stroke oil injected Evinrude on the back of my RIB and am experiencing some running problems.<br />About 3 weeks ago the engine kept dying at full throttle, and would only run at about half the rev range, this turned out to be a faulty impellor which was replaced by a compitent mechanic close to me, the engine has run fine on two consecutive weekends out and even done 75 miles last weekend but while out last Sunday the same dying out at full revs happened again, the engine took ages and ages to get restarted and eventually when we did get it going again all we could do was half revs again which was just enough to get us home.<br />Can this be the impellor again as when i felt the power head the engine felt warm, not red hot but just very warm and the water comming out of the pee hole was also warm, when the impellor failed first time the mechanic removed the thermostate and this has not been replaced yet as we are currently in summer and the engine will run ok without the thermostate there didn't seem any need to replace it at the time, the engine therfore should be running really cold, could this be another problem happening somewhere else which is causing the impellors to go or is it something else ?<br /><br />Thanks for all your help and advise <br /><br />Richard
