evinrude pressurized tank
merkdawg
hello, I know this is not a boat topic,but I have an old pressurized tank that I want to replace the gasket and repaint. Trouble is I can't break all the screws loose. Sprayed them down and let them sit. No luck. Any ideas? Drill the head off then use vise grips? Thx
samo_ott
Re: evinrude pressurized tank
Use a small impact driver. You can get em at Harbor Freight cheap. You hammer it and it turns the screws.
1946Zephyr
Be careful though, that you don't cave in the top of the can.
EddiePetty
Before you do any serious beating on that PO' ole
