Evinrude Fisherman 6
Roland54
Re: Evinrude Fisherman 6
I did have it on start, and past that. The carburator.... looks like a complicated job, I have the manual that shows how to do all that, wanted to see if it will fire up!
bob johnson
you said ..NO SPARK...is that correct still?
no matter your fuel problem...you will need to get spark...
verify you have it
bob
cajuncook1
Check this link that JB wrote:
http://forums.iboats.com/showthread.php?t=158071
This is a snip of his article:
manual start: Flywheel rotates but engine does not attempt to start. .
Remove a spark plug, reconnect it and hold it against engine block. Keep it there while turning engine over.
Does it make a hot, blue spark when attempting to start?
If no, troubleshoot ignition system.
Has hot, blue spark?
Squirt some fuel mix (NOT ether) into the carb(s). Does it attempt to start? *
If yes, you have inadequate fuel. Troubleshoot fuel system and review starting procedure.
This is link how to check your coil, condensors, and points.
http://forums.iboats.com/showthread.php?t=294072
This a basic plan how solve some issues with a motor.
Look at the iboats links I originally supplied, they have links for removing a flywheel, checking the coils, points, condensers, and how to set your points with a feeler gauge.
You will see a lot of experience guys ask about compression, spark and fuel. (They are using a systematic approach to diagnosing an engine problem or problems....in this order)
C= compression ( if your compression is low or uneven between cylinders >10% then others checks don't matter until the that is resolved) (I know you have check compression, but added this for systematic approach information)
S= Spark (if your having problems with your ignition then you can have the cleanest carb and great fuel delivery but it will run bad or not at all)
F= Fuel (if your carbs are not clean and the fast/slow idle needle are not set right then it will run but like crap. If you have it set too lean then you run the risk of poor fuel/oil delivery and damage your pistons and cylinders then you run into the problem of C (poor compression from damage).
cajuncook1
Roland54
I was wondering about the thread size on the 3 screw holes on the flywheel? I have a harmonic balancer, but the assorted bolts are all too big. # 8 means grade 8 right? anyhow , that would be great help
Thanks
Roland54
It is 1/4 screws, just so I understand, the points need to have a gap .20 meaning when I look at them they should not be com-pletely together right? my points sandwiched together, i'll try to gap and see whats happening.
tx1961whaler
1/4"-20, grade 8 or better bolts for the harmonic balancer puller.
0.020" for the point gap
BigB9000
Removing the Carb is a real pain in the Butt. Hopefully you don't have to.
Go here:
http://forums.iboats.com/showthread.php?t=338579
and pull your flywheel off, and see whats wrong with your ignition.
For a novice, I recommend doing the carb last.
If you need step by step picture about how to do anything to that outboard let me know, I have a lot of the 6er's
bob johnson
remember the points only have a gap when the heighest part of the cam pushes them open..otherwise they CAN BE CLOSED!!! ...so gap them ONLY when they are opened on a cam lobe!!!
if I am remember right from my points motor days
bob
1946Zephyr
Great engines. I own a 1974 Johnson 6hp myself and it's a great little runner.
I think your Ford 308 is actually a 302.:D
Anyhow, these little 6's are very simple to work on and very responsive to a good tune up. The one you have there looks to be in nice condition.:cool:
Roland54
Thanks zephir, yeah, 302 4V :D just got the new points and condensers, carb kit and impeller, hope she will fire up this weekend.....
Roland54
Well i got the thing running today!! first pull! the tiller handle is not holding in position to good. Carb is next gotta check the slow and fast needle, I got the carb kit, be checking all the info here!
