BaltimoreDave
Thread starter- Joined
- Jan 16, 2004
- 2
I have a 1971 18' Glasspar boat with a 1979 Evinrude 200 HP engine. The original transom has rotted and I must remove the engine to do the transom replacement work.<br /><br />I have an automobile engine hoist that I hope will be high enough when assembled (it is in pieces now). If not, I plan to reinforce and support one of the ceiling joists in my garage and use the trailer winch to lift the engine.<br /><br />I read a previous message and replies about the proper method of lifting an engine. However, my engine does not have any attached lifting points or eyelets.<br /><br />The Evinrude repair manual shows a heavy duty gear puller type assembly attached to the flywheel with an eyelet in the center of the puller. Unfortunately, it only shows and discusses this method with the lower unit removed. I have no desire to remove the lower unit. I am concerned about lifting the entire engine weight (380 lbs) using only a puller on the flywheel.<br /><br />Does anyone have any suggestions about the proper way to attach the hoist and lift the engine?
