riverfishguy
Thread starter- Joined
- Mar 14, 2012
- 1
Just bought a good running 1991 evinrude e25teeie with a jet lower unit. Due to the area of missouri I live in jets are about the only viable style of outboard for using in our rivers. The motor I bought is a good running unit but i have a narrow hull. (18 x 36 flatbottom jon) I checked part numbers and the crankcase, cylinderhead, pistons, and crankshaft all have the same part numbers on the 25 and 35 hp engines. Id assume I could swap out the intake and carb and convert it to 35 hp? I'm sure im missing something else but the primary parts should just bolt on. My goal is to pick up just enough extra power to make my narrow hull plane out properly. I *think* it can be done if I can safely squeeze 40 hp out of it. Any thoughts?
