Natasha Nadine
- Jun 20, 2004
- 18
Re: evinrude e-tech
100:1 is half the amount, not double you are right but that is far from meeting the target set by Evinrude in their marketing data and owners manual.<br /><br />Normal mix ratio for any two stroke carburated engine is 50:1. The marketing data produced for this engine by Evinrude states that the E Tec uses 75% less oil. That would equate to the following. A typical carburated 2 stroke engine rated at 50:1 (50 liters Gas to one liter of oil) The E Tec should with 50 liters of gas use only 250ml of oil (XD100) Using XD50 for the same amount of gas, 500ml of oil would be used if the info provided in the manual is correct.<br /><br />100:1 may not be bad for the XD50 and XD30 oil but it is most certainly way of the mark for the XD100. Even these figures are way of the mark established by Evinrude for all grades of oil.<br /><br />As noted by Fleet Admiral there is no fuel economy or efficiency associated with the oil consumption.<br /><br />Add the cost of oil (at $15.00 per liter) and fuel together and the cost to operate this E Tec exceeds the cost of operating a typical 2 Stroke. <br /><br />If a comparsion was to be made with the fourstroke I believe that this E Tec is substantially higher yet the market data suggest otherwise.
