Evinrude big twin 40hp wire
Dborun
Would anyone be able to tell me where these red wires go to? They come down from flywheel looks like slate plate. I attached a Pic link
Dborun
Sorry this is the pic
HighTrim
What year is the motor?
There will be 2 wires coming out of the magneto. A wire to each set of points. Originally they were black wires. 1 goes to the TOP post of the vacuum cut out switch you have pictured there. Then another line from that same TOP post goes to the M post of your key switch. The second line from the magneto will go direct to the other M post on the key switch. (there are 2 M posts on a magneto key switch, essentially the kill circuit). What that does, is if there is excessive vacuum created in the intake manifold, as in your motor is experiencing a runaway situation, it will ground 1 set of points. Or, when you turn your key to OFF, it grounds both sets of points, killing the motor.
The small side post you see pictured will also have 2 wires coming off of it. 1 goes to the small post on the starter solenoid, the other to the safety switch.
But please confirm the year of motor or model number we are talking about.
Dborun
Thank you! I just got the boat and trying to figure out the correct wiring since previous owner cut wires. I'll get you more info of motor when I get home.but boat is 65 crestliner model 2030
Dborun
This is the model I think
HighTrim
Yes a 1964. PM me with your email address and ill send you a wiring diagram for it. In case my instructions were not clear. But it is wired incorrectly.
