Evinrude angler 5hp hard to steer
Chiefdillard
Greetings! I am new to the group, I just purchased a Evinrude Angler 5hp, I thought it was good shape for its age, all that I have found is the steering is really stiff and hard. Does anyone have any ideas about this? Thanks in advance!
iggyw1
Ensign
There is a screw that you can turn to loosen or tighten the steering mechagnism on most motors (if not all motors). Just look for an adjustment screw and loosen it a smidge and she should loosen up for you.
Crosbyman
loosen it up big time and see if you can wash out what is likely old dried grease with kerosene or wd-40 . if you y have a zerk (?) push out the old grease with the new
set the screw to your liking after
F_R
Honorary Supreme Mariner
Be realistic. Remove the rear swivel housing, #21, (8 bolts) and clean out the old grease and corrosion, and reassemble with new marine grease.
oldboat1
Welcome aboard Chief. If it's a salt water motor, take some extra precautions before any disassembly -- soak bolts beforehand at a minimum.
