Evinrude age and model from pictures and serial number?
husker199
Can anyone give me this above info for this outboard? serial no. G3117405. It has a johnson 1985 leg on it not the original...
jonesg
Re: Evinrude age and model from pictures and serial number?
Looks like early 80's, only dealerships can read serial numbers.
Transom looks a bit rough.
husker199
thanks.... transom has a plate fitted which is rusting...
EN2
Look's more like 89 or newer. 40/50hp.
husker199
Thanks...... yes its a 50hp
husker199
So if I rang a dealer they could tell me from the serial number?
1946Zephyr
Give them the model number too.
husker199
... thats what I am trying to found out...
boobie
Do I see something that looks like a model # tag on the stern bracket right by the steering cable ?
husker199
yes that is from the Johnson leg......
jonesg
Try reading the part number from the power pack and see which yrs that fits on www.evinrude.com parts lookup.
also the flywheel number and rectifier. You can zero in like that.
husker199
thanks will try that...
