Tom Kanzler
Thread starter- Joined
- Feb 29, 2004
- 1
I have a voltage output question regarding a '78 9.9 long-shaft model 10835M, which has a regulator for battery charging. Disconnected from the battery, it shows somewhere around 50V on an inexpensive digital multimeter (probably very high impedance) with the engine running at high idle. Voltage increases with increased throttle setting, but due to the interlock, I didn't run it above high idle in neutral.<br /><br />I had a battery charger go bad last year, possibly due to being connected to the engine with the battery disconnected, which is what led me to test the output without the battery being connected. Is this a normal output voltage with no connected load, or is there something really wrong with it? I don't want to connect the replacement charger, a Guest 6A, even with the battery being connected, without knowing what normal output is. The boat didn't have a shore-powered charger before I installed the one that fried last year, by the way.<br /><br />Oh, yeah. This is my first post on this forum. I wish I had known about it sooner.
