Evinrude 9.9 voltage output question
Tom Kanzler
I have a voltage output question regarding a '78 9.9 long-shaft model 10835M, which has a regulator for battery charging. Disconnected from the battery, it shows somewhere around 50V on an inexpensive digital multimeter (probably very high impedance) with the engine running at high idle. Voltage increases with increased throttle setting, but due to the interlock, I didn't run it above high idle in neutral.<br /><br />I had a battery charger go bad last year, possibly due to being connected to the engine with the battery disconnected, which is what led me to test the output without the battery being connected. Is this a normal output voltage with no connected load, or is there something really wrong with it? I don't want to connect the replacement charger, a Guest 6A, even with the battery being connected, without knowing what normal output is. The boat didn't have a shore-powered charger before I installed the one that fried last year, by the way.<br /><br />Oh, yeah. This is my first post on this forum. I wish I had known about it sooner. :p
Paul Moir
Re: Evinrude 9.9 voltage output question
Since your meter has (probably) a 10 mega ohm input impedance, your right, your reading may be off. Load the output with a small 12v light bulb (like a 10-15W indicator bulb) and test the voltage again. I think that outboard puts out a ~4amp charge, so a 50w headlight bulb would load it excessivly.
seastream
I've read that it's possible to damage the alternator without a battery connected so I wouldn't do that again. The output of the alternator is unregulated DC & max current is 4 amps as the other post mentions. They get it from a couple of extra coils mounted underneath the flywheel which has magnets cast into it. With a known good battery connected you should see around 14-15 volts or so even at full throttle in gear since a good battery (I saw 17-20 with a bad batt) tends to load down the alternators output. Good Luck.<br /><br />Bob
