reeldutch
- Feb 2, 2004
- 1,340
Re: Evinrude 88 SPL overheating (pics)
sometimes yellow jackets crawl into the idle relief ports and start building nests in there.
you should be able to blow everything out while you have the lu off.
stick the power washer in there and give a couple short bursts.leave the tstat housing off. while doing this.blow trough the idle relief ports also.
when i rebuild a motor and before i install the ph
i just blow out the hole midsection and give it a coat of paint.
those darn yellow jackets get into the weirdest spots.
good luck
good luck
