Evinrude 86 15 hp waterpump change
garcam
Newbe here. I just bought a used motor and I'd like to get out in this weekend if possible. I don't have a repair manual yet and I'd like to replace the impeller.
Can someone tell me if I need to know anything special about this job?
I expect I'll unbolt the lower unit and remove it? Does the shifter need to be in reverse or anything?
What can I expect in terms of getting the pump housing off? It's been in saltwater, but seemingly well maintained.
Thanks for your help.
I intend to learn how to service this moter and keep it for a long time. It's a great thing to have this website and folks like you!
ezeke
Re: Evinrude 86 15 hp waterpump change
If you go to the following site and read, or print and read, the literature, it will help. Then if you have specific questions someone can give you a hand.
http://www.wisnersinc.com/Fishing Info/Lower_unit.htm
There are many items about the 9.9 and 15 on that website If you go here and navigate to the bottom of the page:
http://www.wisnersinc.com/Fishing Info/Fishinginfo_main.html
Those are large files with a lot of pictures, so give them time to download, then save them..
garcam
THANK YOU SIR!
Thanks so much for this website listing.
I have looked at it before, however I did not see the articals about the 15hp motor.
Thanks again!
garcam
