Evinrude 70hp: ?year + trim option
poly_span
I have an Evinrude 70hp outboard motor (model # 70573E and serial # A113560) on my 4.5m Dover half cabin.<br />Can anybody please tell me:<br />-what year is this motor,<br />-where I can get a service/repair manual,<br />-and can I get an electric power-trim accessory/add-on for this model?<br /><br />Thank you<br />Jonathan Dowling,<br />Melbourne Australia
Jilly - 5
Re: Evinrude 70hp: ?year + trim option
Get a Seloc manual. There are pages in the back that interpret the model number and letter. You should have one anyway. Mine is at the country place. I'll reference it this weekend.
JB
G'Day, Jonathan.<br /><br />Welcome to iboats. :) <br /><br />Your engine is a 1975.<br /><br />You can get an aftermarket manual here: http://www.boatmotors.com/manuals.html <br /><br />Or the recommended OEM Manual here: http://www.kencook.com <br /><br />Yes, you can convert your engine to T&T, either by adding an assembly from an original or by adding an aftermarket kit.<br /><br />Good luck. :)
poly_span
Thank you to all of you that have replied so promptly - what a wonderful forum this is. Am very proud to be an Australian, but I doubt you'd get this sort of support & assistance so readily 'down' here.
poly_span
Why does Jim Matthews say to dump it?<br />-It seems to run okay (except have to lift cover and adjust manual choke to start when cold). Do you know something I don't and/or am I wasting my time servicing a motor this old???<br />Jonathan
WillyBWright
Actually there are several regulars from Australia and New Zealand that hang out here.<br /><br />About the choke, there may be three positions for it. Off, Auto, On. The electric choke will only work in the Auto position. Off and On override it.<br /><br />Treat the motor with a decarbonizer at least annually. The demise of many of those was carbon building-up behind the rings. Others died from lean conditions caused buy air leaking past wear on the throttle shafts.
jfm1
Jonathan I did;nt say dump it Thats just a phrase I use FIX IT DON'T JUNK IT
poly_span
sorry, the way it appears is: Fix it don't. (stop) Junk it. Considering you all drive on the wrong side of the road, I should have reversed the punctuation. Thank you again for your kind reply.
