Evinrude 6hp fuel pump problem
lexus258
I've pulled the fuel pump and it has the following serial no. on the back which refers to a 9.5 hp model. Will this effect the running of my 6 hp??
304089
It is running but when WOT without pumping the primer bulb it dies.
Thanks
AlTn
Re: Evinrude 6hp fuel pump problem
as hidef said in your other thread...if this is working properly it will not effect the running of your engine, if the motor runs properly while you pump the primer bowl, that's a classic fuel pump/fuel delivery problem...as hidef stated..the f/p number 304089 has superceded to 0388685 which is listed for a 1972 6 hp....if you look at numerous 2 cylinder engines of a given year, or number of years, they'll all use the same fuel pump
